Temperature monitoring
Hello!
I bought a LAN controller.
Is it possible to record the history of temperature?
In order to be able to see the temperature of the previous day, week, month?
Thanks for the reply!
Greetings from Ljubljana!
try with thingspeak.com or use raspberryPI with software to collect data
You can also use cacti which gathers snmp information and creates a nice graphs for you.
If you don't know how to create new graphs I could do this for you, but cacti installation you have to do on your own. http://cacti.net/
This looks something like this:
.png   mt_temperature.png (Rozmiar: 62.91 KB / Pobrań: 8,454)
On this example this is mikrotik router temperature, but it's basically the same with anything.
Thingspeak is the way to go. Very good monitoring options with alarms via Twitter with React app. It sounds a bit silly but works very good and is stable. Greetz
First , thanks for help...
I'm not sure that I understand thingspeak.com. Confusedhock:
I can not set parameters. :oops:
Where can I get the template for lan controler.
I use only the temperature sensor INPUT6 - 9
Thank you for help...
Regards....
Damjan
This is probably because there is no english manual for LK.
Nobody record temperature with LAN controller?
Please help !
We have provided you with two seperate solutions for you problem already.
You can also use Mikrotik's The dude, but cacti is a better way to go.
Is cacti for windows or linux ?
I have windows 7
Regards
Finally, work my THINGSPEAK Channel.
Acknowledgements to mr. Marcin Nosek ( Konsorcjum ATS )
Thank You mr. Nosek !
