Temperature monitoring - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler - wersje oprogramowania (https://forum.tinycontrol.pl/forumdisplay.php?fid=4) +---- Dział: Przykłady zastosowań przez użytkowników. (https://forum.tinycontrol.pl/forumdisplay.php?fid=6) +---- Wątek: Temperature monitoring (/showthread.php?tid=685) |
Temperature monitoring - svedr - 02-12-2016 Hello! I bought a LAN controller. Is it possible to record the history of temperature? In order to be able to see the temperature of the previous day, week, month? Thanks for the reply! Greetings from Ljubljana! Re: Temperature monitoring - levykrak - 02-13-2016 try with thingspeak.com or use raspberryPI with software to collect data Re: Temperature monitoring - naven - 02-13-2016 You can also use cacti which gathers snmp information and creates a nice graphs for you. If you don't know how to create new graphs I could do this for you, but cacti installation you have to do on your own. http://cacti.net/ This looks something like this:
On this example this is mikrotik router temperature, but it's basically the same with anything. Re: Temperature monitoring - shafter - 02-15-2016 Thingspeak is the way to go. Very good monitoring options with alarms via Twitter with React app. It sounds a bit silly but works very good and is stable. Greetz Re: Temperature monitoring - svedr - 02-15-2016 First , thanks for help... I'm not sure that I understand thingspeak.com. hock: I can not set parameters. :oops: Where can I get the template for lan controler. I use only the temperature sensor INPUT6 - 9 Thank you for help... Regards.... Damjan Re: Temperature monitoring - shafter - 02-16-2016 This is probably because there is no english manual for LK. Re: Temperature monitoring - svedr - 02-18-2016 Nobody record temperature with LAN controller? Please help ! Re: Temperature monitoring - naven - 02-18-2016 We have provided you with two seperate solutions for you problem already. You can also use Mikrotik's The dude, but cacti is a better way to go. Re: Temperature monitoring - svedr - 02-18-2016 Is cacti for windows or linux ? I have windows 7 Regards Re: Temperature monitoring - svedr - 02-22-2016 Finally, work my THINGSPEAK Channel. Acknowledgements to mr. Marcin Nosek ( Konsorcjum ATS ) Thank You mr. Nosek ! |
