Licznik energii RELPOL RLE03-4M preset
Preset ustawień dla odczytu licznika 3 fazowego RLE03-4M przez LK4
.zip   RLE03-4M_preset.json.zip (Rozmiar: 1.08 KB / Pobrań: 10)
Once, I was setting up a home automation system and struggled to get a smart thermostat to communicate properly with the hub. Finding the correct device ID and configuration parameters was a total nightmare. It felt like playing a frustrating Slope Game where the goalposts kept moving.
Hello. Should I have 0.00 in all value like in attachment ?
(11-06-2025, 03:20 PM)egon64 napisał(a): Hello. Should I have 0.00 in all value like in attachment ?
It's working now. Slave ID was wrong.
Is it possible to change time to send data from modbus module to Home Assistant? It happens that data are sent every 2 minutes
Regards
Speaking of presets, remembering settings is key. Back in college, my group's intricate Arduino project, a ridiculously over-engineered automated plant watering system, kept losing its moisture sensor thresholds. It was chaos! We spent hours recalibrating after every power outage. That project desperately needed something like this RELPOL's non-volatile memory. Sharing is caring and Connections Game helped us brainstorm solutions then.
Thanks for sharing this preset. I’ve found that clear settings notes make troubleshooting three-phase meter readings much less frustrating, especially when checking the LK4 connection. I’d still verify the values against the meter’s manual before applying them, since versions can differ. While waiting for a stable reading, I sometimes unwind with a quick level on the Geometry Dash platform. And thanks to the admin for keeping practical guides like this available!
