After connecting via wifi, NTP is not active - the clock is not updated after a power failure. Time 1970-01-01 01:20:17
LK4 NTP
11-25-2023, 11:09 PM
(10-15-2023, 03:27 PM)Igi71 napisał(a): After connecting via wifi, NTP is not active - the clock is not updated after a power failure. Time 1970-01-01 01:20:17 we fix this in next soft version
11-28-2023, 11:59 PM
(11-25-2023, 11:09 PM)wilkxt napisał(a):(10-15-2023, 03:27 PM)Igi71 napisał(a): After connecting via wifi, NTP is not active - the clock is not updated after a power failure. Time 1970-01-01 01:20:17 we check this and it works ok in soft version 1.08
11-30-2023, 07:57 PM
(11-28-2023, 11:59 PM)wilkxt napisał(a):(11-25-2023, 11:09 PM)wilkxt napisał(a):(10-15-2023, 03:27 PM)Igi71 napisał(a): After connecting via wifi, NTP is not active - the clock is not updated after a power failure. Time 1970-01-01 01:20:17 Uptime 55 sec, 52 min, 0 hour, 0 day Čas 1970-01-01 01:52:55 SW 1.08 | HW 1.0
12-01-2023, 09:21 AM
(11-30-2023, 07:57 PM)Igi71 napisał(a):Do you have the appropriate network settings configured?(11-28-2023, 11:59 PM)wilkxt napisał(a):(11-25-2023, 11:09 PM)wilkxt napisał(a):(10-15-2023, 03:27 PM)Igi71 napisał(a): After connecting via wifi, NTP is not active - the clock is not updated after a power failure. Time 1970-01-01 01:20:17
tomek |
