RELAY AFTER START-doesnt working
#21
wilkxt napisał(a):soft is in microkontroler not eeprom, but problem that LK not run is eeprom.
In LK1.2 eeprom has adres 0, but in LK2.0 eeprom has adres 2.
In LK1.2 pin2 in eeprom is connected to GND, unconnect them and connect pin2 to VCC (3,6V), now tray run LK, if run (propably on last IP or default IP 192.168.1.100) upgrade to lk1,2 soft version and connect pin2 to gnd.
Thank you so match ,
Problem solved.LK is working.
