Propozycje nowych funkcjonalności
#21
Obecna wersja oprogrmaowania pozwala na podłączenie 4 czujników temperatury poprzez 1wire. Czy jest szansa aby była mozliwość wprowadzenia własnych nazw dla tych czujników ?
w wersji HOME będzie taka mozliwość
I am planning to use several of your pieces to control my very long term timelapse photography - together with other equipment it will take every 10 minutes new photo, for next two years Smile)
I can solve with your hardware variety of my tasks, like watchdog, overheating etc... But I also need to set up trigger for camera. So my question is, how hard is to add timer function to your firmware? I need to switch on relay periodically, for example every 10 minutes. (means I need a short impulse every period of time). Range in seconds will be fine, longest period I have ever used is couple of hours.
How hard is to write these timer function to your firmware, and what sould I do to convince you to make it?
Thank you very much for your answer.
savalish napisał(a):I need to switch on relay periodically, for example every 10 minutes. (means I need a short impulse every period of time). Range in seconds will be fine, longest period I have ever used is couple of hours.
How short impulse you need? Tel me min and max impulse time?
Length of impulse is not crucial and is hard to be set preciously. I am using this for capturing photos on DSLR cameras, so when relay switch on, camera need to focus for a while and capture photo. So the switch on time could vary in a seconds (10 sec max, usualy less). Switch off time means, how often a photo will be captured, this could vary between 1 minute to an hour. In a meantime, I have tested usage with regular firmware. I have used watchdog function, set up an IP which cannot replay and set 10 mins interval for testing - no response led to 10 sec reset which cause camera to take a picture. But this is very bad solution, because it limits watchdog function itself for other purpouse (I need to test router and whole internet connection, because pictures are automatically backed up online).
Thank you for your help. Jakub
Czy można dodać licznik impulsów przyrostowy
Zastosowanie np. inteligentny dom , licznik energii elektrycznej mamy z niego impulsy, podłączamy lan kontroler i z zdalnej maszyny odczytujemy licznik po SNMP i robimy sobie wykresik na zdalnej maszynie
Potrzeby będzie licznik przyrostowy , może być ulotny po resecie modułu
We add this function in this firmware http://www.tinycontrol.ats.pl/forum/view...?f=2&t=412
cinas napisał(a):Witam
Tak, pojawi sie taka opcja w jednej z wersji softu
Mam kilka propozycji zmian które nasunęły mi się podczas dwumiesięcznej eksploatacji 4 szt. LK (świetny kontroler) połączonych
po Wi-Fi (soft 2.28) . Zastosowanych jako kontrola i regulacja temperatury w 3 pomieszczeniach wraz z kontrolą i regulacją temperatury grzejników oraz 1 LK jako kontrolera pracy kotłowni i pieca CO i CWU oraz kilku innych rzeczy. Część tych propozycji była już sygnalizowana na forum.
I tak.
- Host name z panelu Network Configuration widoczna na panelu kontrolnym - przydatna dla użytkowników więcej niż jednego LK.
- panel kontrolny na jednej stronie widoczny w całości bez scrollu
( Wyeliminowanie scrollu znacznie ułatwia ocenę sytuacji na panelu i stosowane jest w przemyśle przy wizualizacji procesów technologicznych czy kontroli systemów i wygląda bardziej profesjonalnie ).
- wyróżnienie kolorem stanu wejść cyfrowych podobnie jak w przypadku przekaźników lub podobnie np. różne kolory LOW, HIGH
Dla w/w zmian nie powinno być chyba problemu z pamięcią. Tak mi przynajmniej wygląda z zapisu HTML.
Można by to zrobić np. jak w załączniku. Jeśli uzna Pan że jest warte dyskusji, proszę umieścić załącznik na forum.
- nadanie nazwy własnej wejściom cyfrowym - podobnie jak przekaźniki
- nadanie nazwy własnej czujnikom temperatury 1-Wire zamiast napisu DS18B20 1-Wire
Dla dwóch ostatnich zmian być może udało by się coś wygospodarować – to w końcu „tylko” 8 zmiennych
Myślę że zmiany te nie powinny obejmować tylko wersji Home a wersję podstawową. Zadowoliły by chyba każdego użytkownika LK
niezależnie od tego do czego go wykorzystuje.
.gif   rysunek1.gif (Rozmiar: 32.69 KB / Pobrań: 5,797)
Myślę, że propozycja ciekawa, postaramy się nad nią pochylić
