PWM frequency - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V3 (https://forum.tinycontrol.pl/forumdisplay.php?fid=27) +--- Wątek: PWM frequency (/showthread.php?tid=953) |
PWM frequency - hapi - 10-01-2019 hi When the board off / on then it has a different frequency than I set. The interface writes that it has mine set, but it does not output it. The set frequency is only activated when I move the duty slider. Until then, it is still set to default. All firmware. RE: PWM frequency - tomekO - 10-01-2019 HEllo, You must write more Information like: Hw version Firmware version what accessory connect, ETC. Best Regards tomekO RE: PWM frequency - hapi - 10-02-2019 I'm in the LK3 section and I also wrote that all firmware does it. 1.55 does it too. RE: PWM frequency - tonymony - 10-02-2019 I've tested on LK3.0 v1.55 with multimeter. When pwm output is turned on, changes in frequency box result in change in multimeter, without need of changing duty. Though the duty must be non-zero (my multimeter was unable to measure frequency when duty was <20% and frequency was 100k Hz). As for turning board on/off the state of output is not preserverd after restart, so by default the pwm output is turned off and there is no output signal. RE: PWM frequency - hapi - 10-02-2019 yes, and when you turn on the output, it has a default frequency. Not set. No shift duty. RE: PWM frequency - wilkxt - 10-11-2019 We fix it, in next firmware RE: PWM frequency - hapi - 11-18-2019 (10-11-2019, 11:00 PM)wilkxt napisał(a): We fix it, in next firmware ok, when will the next firmware? RE: PWM frequency - wilkxt - 11-18-2019 (11-18-2019, 08:29 PM)hapi napisał(a):(10-11-2019, 11:00 PM)wilkxt napisał(a): We fix it, in next firmware about 2-3 weeks RE: PWM frequency - wilkxt - 02-12-2020 fixed in v1.56 (public about 2-3 days) |
