SONOFF and LK3 - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V3 (https://forum.tinycontrol.pl/forumdisplay.php?fid=27) +--- Wątek: SONOFF and LK3 (/showthread.php?tid=889) Strony:
2
SONOFF and LK3 - SV2BZQ - 12-19-2017 Hi ... I've bought here : https://www.banggood.com/DIY-Wi-Fi-Wireless-Switch-For-Smart-Home-With-ABS-Shell-p-1019971.html?rmmds=myorder&cur_warehouse=CN . It could be joined to LK3 ??? George. Re: SONOFF and LK3 - notek - 12-19-2017 SV2BZQ post_id=15581 time=1513689165 user_id=6105 napisał(a):Hi ...Yes, but you have to put Sonoff Tasmota firmware and configure for further work. We sell prepared Sonoff Basic with this firmware and have manual how to setup. Re: SONOFF and LK3 - SV2BZQ - 12-19-2017 notek post_id=15582 time=1513694567 user_id=59 napisał(a):SV2BZQ post_id=15581 time=1513689165 user_id=6105 napisał(a):Hi ...Yes, but you have to put Sonoff Tasmota firmware and configure for further work. Ok thank you for answering it .... Re: SONOFF and LK3 - SV2BZQ - 12-21-2017 notek post_id=15582 time=1513694567 user_id=59 napisał(a):SV2BZQ post_id=15581 time=1513689165 user_id=6105 napisał(a):Hi ...Yes, but you have to put Sonoff Tasmota firmware and configure for further work. Ok i put Sonoff Tasmota firmware all ok and I can handle it through via mqtt.ats.pl . But I have not managed to work it via LK3 . :oops: Some help with the LK3 setup ???? :?: Thanks for the time ..George Re: SONOFF and LK3 - wilkxt - 12-21-2017 set sonoff out by LK3. LK3 setings: 1.In http client set sonoff IP and remote url: ay?o=1 2.Do not enable http client send, if you enbale it, sonoff out will be swithced on/off by http client time 3. In events set out as http client Now if events occur then set url by http client to sonoff Re: SONOFF and LK3 - SV2BZQ - 12-22-2017 wilkxt post_id=15593 time=1513883306 user_id=61 napisał(a):set sonoff out by LK3. Thank you for the immediate answer . All ok . 2 questions : 1) since it uses http client for WR-01 how to update the thingspeak since there is no other http client in LK3 ?? :?: 2) if you can change from out2 to outxx ? :?: George. Re: SONOFF and LK3 - wilkxt - 12-26-2017 SV2BZQ post_id=15595 time=1513943487 user_id=6105 napisał(a):1) since it uses http client for WR-01 how to update the thingspeak since there is no other http client in LK3 ?? :?: +Yes, it is impossible now, but, next soft we add additional http client settings to do this SV2BZQ post_id=15595 time=1513943487 user_id=6105 napisał(a):2) if you can change from out2 to outxx ? :?: change where? Re: SONOFF and LK3 - SV2BZQ - 01-28-2018 wilkxt post_id=15603 time=1514279556 user_id=61 napisał(a):SV2BZQ post_id=15595 time=1513943487 user_id=6105 napisał(a):1) since it uses http client for WR-01 how to update the thingspeak since there is no other http client in LK3 ?? :?: +Yes, it is impossible now, but, next soft we add additional http client settings to do this Hi again. We have information about this ??? George. Re: SONOFF and LK3 - wilkxt - 01-29-2018 We're still working on a new soft Re: SONOFF and LK3 - SV2BZQ - 01-29-2018 wilkxt post_id=15629 time=1517211869 user_id=61 napisał(a):We're still working on a new soft Τhank you for your immediate answer . I wait with anguish . George. |
