Auth enabled - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V3 (https://forum.tinycontrol.pl/forumdisplay.php?fid=27) +--- Wątek: Auth enabled (/showthread.php?tid=851) |
Auth enabled - octavvian - 10-09-2017 Hi, when enabling auth in the access page, result in denying access to panel. Password not recognized... fw 1.43b, same in 1.40b Thanks! Re: Auth enabled - wilkxt - 10-19-2017 what browser yo use, what is communicat? Re: Auth enabled - octavvian - 10-20-2017 Hi, I'm using firefox. Without auth enabled it's working OK. After enabling the auth window appear but giving the right credentials I can't get login. Thanks. Re: Auth enabled - wilkxt - 10-20-2017 tray to change to standard user i pass:admin/admin and check Re: Auth enabled - octavvian - 10-22-2017 OK, I'll try some more. Late edit. Now it working, maybe was the browser. Strange. Anyway, thanks for the tip. Re: Auth enabled - octavvian - 10-28-2017 Hi, one more , if u set in "events" let's say INP1D = 0 then OUT0 will change state and in "control/out" for OUT0 set reset time to 2s, this option will not execute when INP1D=0 the OUT0 stay 1 as long as the INP1D, no reset after 2 sec on OUT0. If you change state of OUT0 manually from "control/out" page, the reset time it's working but not from an event.Any idea pls. Re: Auth enabled - wilkxt - 10-29-2017 We check this Re: Auth enabled - octavvian - 10-30-2017 Thanks, appreciated. P.S. fw 1.42b Re: Auth enabled - octavvian - 11-02-2017 Hi, any chance on looking at that issue? Thanks Re: Auth enabled - wilkxt - 11-02-2017 yes, we repair this in next soft |
