DHCP Problem with LK3 - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V3 (https://forum.tinycontrol.pl/forumdisplay.php?fid=27) +--- Wątek: DHCP Problem with LK3 (/showthread.php?tid=836) |
DHCP Problem with LK3 - ghorvat - 09-01-2017 Hello, I have a problem with one of the LK3's I own. The device was working normal for weeks now, and suddenly it stopped working. When I tried to connect to the LK3 it was not visible on the LAN. So reverted to factory settings (long press of the button) and then the device works only with default IP. When I enable DHCP I get ON-ERROR. I do not understand what could be the problem. I have other LK3 connected to the same router, and it works normal. This is the log from the UART console connected to the LK3 ..Bootloader LK3 start ...check firmware.... ...HW version=1.0. ...begin firmware ready. ...end firmware ready. ...start firmware........ ...Firmware LK3 start. ......HW version=1.0. ...SW version=1.42b. ...RTC module not connected. . ...FS_root addres=186100. ...BME280 not detected. ...ETH config ok. ...EEPROM start read. ...DHCP ON...wait for IP address. ...HTTP port is 80. ...EEPROM end read. . ...wait.... ...DHCP ERROR. ...IP is 192.168.1.100 . ...MASK is 255.255.255.0 . ...remote udb bind OK. Re: DHCP Problem with LK3 - wilkxt - 09-08-2017 We will chech this |
