Connecting LCD to LK3 using UART - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V3 (https://forum.tinycontrol.pl/forumdisplay.php?fid=27) +--- Wątek: Connecting LCD to LK3 using UART (/showthread.php?tid=780) |
Connecting LCD to LK3 using UART - ghorvat - 03-10-2017 Hello everyone! My name is Goran and I am new to the forum! I would like to know would it be possible to connect an LCD display to LK3 ? I see that the LCD is not included in the accessories, but I would like to know would it be possible to connect an LCD using the UART present on the LK3? In this case, I would program a micro controller to talk to the LK using UART, and display the parameters such as IP address, input values etc. on the display. My question is: what parameters could be accesses using the UART on the LK3? The manual only states "console preview"? Thanks! Re: Connecting LCD to LK3 using UART - wilkxt - 03-11-2017 Hi we plan add LCD to lk3 by SPI port. BY uart console you only view state LK3 and what now doing, etc. send http client, or mqtt Re: Connecting LCD to LK3 using UART - ghorvat - 03-13-2017 When can we expect this to be integrated in LK3? Re: Connecting LCD to LK3 using UART - wilkxt - 03-20-2017 Propably this month Re: Connecting LCD to LK3 using UART - ghorvat - 05-04-2017 Hello Any news regarding the firmware upgrade to support LCD? Re: Connecting LCD to LK3 using UART - wilkxt - 05-04-2017 We added support to OLED 128*64 0.96 inch 4pin OLED Module SSD1306 Drive,I2C like this https://pl.aliexpress.com/item/Wholesale-0-96-inch-4pin-White-OLED-Module-SSD1306-Drive-IC-128-64-I2C-IIC-Communication/32658908775.html?isOrigTitle=true. As we finish the tests, we will provide a new firmware Re: Connecting LCD to LK3 using UART - ghorvat - 05-04-2017 That would be great! Also, do you plan to integrate support for barometric air pressure sensor (for example BMP180) ? Re: Connecting LCD to LK3 using UART - wilkxt - 05-07-2017 ghorvat napisał(a):That would be great!Yes we plan add air pressure sensor |
