LAN Controler V3 does not work. - Wersja do druku +- Forum Tiny Control Solution (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V3 (https://forum.tinycontrol.pl/forumdisplay.php?fid=27) +--- Wątek: LAN Controler V3 does not work. (/showthread.php?tid=772) |
LAN Controler V3 does not work. - bahos73 - 02-22-2017 Hello, I bought Lan Controller V3. After turning on everything worked OK, but after setting the remote management over mqtt.ats.pl device has been restarted and no longer works. I am trying to connect over www (192.168.1.100) and failed. Instead of the web interface to see the report, 404: The requested file cannot be found. Please do you have any recomandation how to fix the problem? I already tried to full resset but unsuccessfuly. Thank you for any help. Re: LAN Controler V3 does not work. - wilkxt - 02-26-2017 Hi put this new software to LK3 http://tinycontrol.pl/forum/viewtopic.php?f=28&t=6024 instruction how tu put new software http://www.tinycontrol.pl/tinycontrol/en/pliki/LK_v30_UPGRADE_short_manual_A6_EN.pdf |
