DTH22 showing ZERO - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler - wersje oprogramowania (https://forum.tinycontrol.pl/forumdisplay.php?fid=4) +---- Dział: Przykłady zastosowań przez użytkowników. (https://forum.tinycontrol.pl/forumdisplay.php?fid=6) +---- Wątek: DTH22 showing ZERO (/showthread.php?tid=707) |
DTH22 showing ZERO - seramea - 03-28-2016 Hello, From time to time DTH22 sensor is showing zero humidity and zero temperature. Any ideea why? I am having conected to "LAN CONTROLER" an relay board which is having a heater and two ventilators. I have to restart the board to fix the problem. Thanks for your answer. Cześć, Od czasu do czasu czujnika DTH22 wykazuje zerową wilgotności i temperatury zera . Wszelkie ideea dlaczego? Mam conected do "LAN Controler " deska do przekaźnika , który jest o grzałkę oraz dwa wentylatory . Muszę ponownie uruchomić płytę , aby rozwiązać problem . Dzięki za odpowiedź. Re: DTH22 showing ZERO - seramea - 04-04-2016 Any ideea? Re: DTH22 showing ZERO - wilkxt - 04-13-2016 you must restrt board to fix problem? Or value 0 are only by moment? Re: DTH22 showing ZERO - levykrak - 04-14-2016 First you should try disconnect power to DHT. If this fix your problem buy new one sensor Re: DTH22 showing ZERO - seramea - 04-18-2016 Thank for your answer. I have to unplug the power for the board. Restarting from the webpage is not fixing the problem. I have seen that the problem is starting when an relay is going on ON. I have an relay board with four power relay. I will try to buy a new sensor. I even try to add an capacitor between vcc and gnd but is not fixing the problem |
