DHT22 senzor , wrong humidity - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler - wersje oprogramowania (https://forum.tinycontrol.pl/forumdisplay.php?fid=4) +--- Wątek: DHT22 senzor , wrong humidity (/showthread.php?tid=705) |
DHT22 senzor , wrong humidity - svedr - 03-23-2016 Hello! I use LH v. 3.13 and senzor DHT 22 for temperature and humidity. Temperature shows OK, but humidity is usually always 99.9%, The lowest value is 88%. Senzor is outside. Now is value 88%, correct is 55-60% what is wrong? regards Re: DHT22 senzor , wrong humidity - pat - 03-24-2016 Check or change sensor. I had the same problem with DHT22 outside. Regards. Re: DHT22 senzor , wrong humidity - iwi - 06-13-2016 What is life yours sensors (DHT22 or DHT11). My first sensor DHT11 was destroyed after 3 or 4 months. Second DHT22 after 5 months. Third after 4 months. What is yours experience with this sensors? But all the time the sensors was working correctly. |
