Q/A ENG update / firmware - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler - wersje oprogramowania (https://forum.tinycontrol.pl/forumdisplay.php?fid=4) +--- Wątek: Q/A ENG update / firmware (/showthread.php?tid=70) |
Q/A ENG update / firmware - urosv - 08-12-2012 Hi guys, Is there any new English firmware >= 2.2 and is there possibility to modify web page of LAN controller ? What is with English language forum and Q/A ? Re: Q/A ENG update / firmware - wilkxt - 08-13-2012 urosv napisał(a):Hi guys,All firmware are English urosv napisał(a):is there possibility to modify web page of LAN controller ? What you want to modify? urosv napisał(a):What is with English language forum and Q/A ?We need to think about it Re: Q/A ENG update / firmware - urosv - 08-13-2012 Thanks for your quick and simple replay ![]() ' napisał(a):What you want to modify? We would like to give a basic web page a new design for our hardware application custom made. We would like to implement your Lan controller to OffGrid solar power plants with some extra design and diagnostics features. New gauges modules etc. Since you have a great way to have web implemented into board itself we do not need for third party software (SNMP) to be extra build. We just need access to this API part of your board. Is this anyhow possible ? Thanks for replay Re: Q/A ENG update / firmware - wilkxt - 08-16-2012 urosv napisał(a):New gauges modules etc. Since you have a great way to have web implemented into board itself we do not need for third party software (SNMP) to be extra build. We just need access to this API part of your board. Is this anyhow possible ? We can prepare for you a special firmware, you must give us: 1.The project site 2. The precise functions describe, what to do, etc. We need to assess whether it is possible that the hardware(memory flash,RAM, analog input, etc.) allows it. Re: Q/A ENG update / firmware - kyncl - 09-20-2012 Hi, I have 3 pcs of the LanKontroler (I use 3.0 and 2.24 fw) as a first I would like apreciate this very powerfull HW and FW. So now my questions I have tried to connect to the device DS18B20 sensors but if I connect more than 3 sensors device rejects to start, if I disconnect third sensor (any) LanKontroler starts normaly. I tested on all devices with different fw versions and behavior is same or similar. So now I can use only two DS18B20 sensors. Second question is about future support other Dallas one wire sensors (counters etc.) Is there any plan for next release of FW ? Thanks and Best Regards Jan Kyncl Prague Re: Q/A ENG update / firmware - wilkxt - 09-22-2012 kyncl napisał(a):Hi, We must check it kyncl napisał(a):Hi, Yes, we plan this in 3.xx series firmware Re: Q/A ENG update / firmware - kyncl - 09-29-2012 Hi would like report strange behavior after upgrading to the 2.25 fw. I tried to upgrade from 2.24 to 2.25 and after upgrading one device change MAC address to 00:00:00:00:00 second device got some random MAC different from previous So I manualy change itvto the original MAC addreses which I had stored Best Regards Jan PS: Problem when device reject to boot when I have connected more than 3 Dallas senzors persists with fw 2.26 Re: Q/A ENG update / firmware - wilkxt - 10-01-2012 kyncl napisał(a):Hi would like report strange behavior after upgrading to the 2.25 fw.It is recommended to do settings reset (hold button reset about 10 seconds) kyncl napisał(a):PS: Problem when device reject to boot when I have connected more than 3 Dallas senzors persists with fw 2.26We chceck it soon |
