GSM-V2 Does not dial out - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: Kontrolery GSM (https://forum.tinycontrol.pl/forumdisplay.php?fid=29) +--- Dział: GSM kontroler GSM (https://forum.tinycontrol.pl/forumdisplay.php?fid=5) +--- Wątek: GSM-V2 Does not dial out (/showthread.php?tid=523) |
GSM-V2 Does not dial out - sda - 12-01-2014 Hi, I am from Greece and have bought the above unit about a year ago, and have decided to use it now. The problem that I am having setting up the outgoing number. Your user manual your example is : 1234 et:number:1:123456789In Greece we use 10 digit numbers for mobile telephones instead of 9 (as in your example) So it should be: 1234 et:number:1:0123456789I have no idea of what version software the module has, as I cannot get a reply from it. Any help is much appreciated Kindest regards, Sarantos Agiakatsikas Re: GSM-V2 Does not dial out - wilkxt - 12-19-2014 check soft version, use comand:1234 tatus et
RE: GSM-V2 Does not dial out - JudyMullins - 11-08-2020 The tilte of the contribute is followed for the candidates. Paths of the article and essayhave are shifted for the goals. Margin is placed for the fixing of the goals in the Madoff the contribute and fieldwork for the agencies. RE: GSM-V2 Does not dial out - hoadao3493 - 01-29-2022 Your article is very good and useful, thank you for sharing, mig8 hopes that next time you will have more good articles to send to all readers. RE: GSM-V2 Does not dial out - AfonsoS - 11-02-2026 If the unit is not replying to commands, ensure the SIM card has its PIN lock disabled via a regular phone and active SMS credit on a supported 2G/3G network. |
