INP3D & Energy measure - FW error? - Wersja do druku +- Forum Tiny Control Solution (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler - wersje oprogramowania (https://forum.tinycontrol.pl/forumdisplay.php?fid=4) +---- Dział: Przykłady zastosowań przez użytkowników. (https://forum.tinycontrol.pl/forumdisplay.php?fid=6) +---- Wątek: INP3D & Energy measure - FW error? (/showthread.php?tid=491) |
INP3D & Energy measure - FW error? - PavelV - 10-19-2014 Hi developers, I have LAN Controller HW 1.2, FW latest - 3.22. I would like to measure the energy (kWh). I'm using the INP3D input, but it works wrong. When I shorted INP3D to GND, the counter (kwh) didn't stop count. I think that counter should count the pulses. I didn't generate any pulse. You can see it the video file - https://dl.dropboxusercontent.com/u/62359529/LAN.avi Could you answer to my questions? 1) Is it mistake? 2) Could you create new firmware with correct function? 3) How much pulses could it catch in 1 second max? 3-5 pulses/1s ? Is it possible to catch faster pulses or should I use the HW divider? Thank you, I will wait for your answers Pavel Re: INP3D & Energy measure - FW error? - PavelV - 10-20-2014 Hi, I find FW 3.29P - http://www.pvmonitor.pl/sprzet.php It has 2 counters. It looks better. I will test it. Re: INP3D & Energy measure - FW error? - andre - 10-20-2014 @PavelV Possibly go back to version, 3.18 version 3.22 has a bug. I had the same |
