Scheduler data and NTP - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler - wersje oprogramowania (https://forum.tinycontrol.pl/forumdisplay.php?fid=4) +--- Wątek: Scheduler data and NTP (/showthread.php?tid=40) |
Scheduler data and NTP - sbegnozzi - 05-29-2012 Hi, I need to set the scheduler for same day, example out 0 on at Monday and Tuesday 8.30, but there is not possibility to change in manual set the day, only the data and time not day. If I try to set NTP, seems that it is impossible change the NTP adress, when I take out power and than restart the old adress return. firmware version 2.13 Please I need you help to set correctly the scheduler Thank you Re: Scheduler data and NTP - wilkxt - 06-16-2012 You can change day, exemple: Mo-Monday Tu-Thursday, etc. 0,Sa;Fi,23:22:03 out0 set in Saturday and Friday |
