NonBoot LanControl - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler - wersje oprogramowania (https://forum.tinycontrol.pl/forumdisplay.php?fid=4) +--- Wątek: NonBoot LanControl (/showthread.php?tid=366) |
NonBoot LanControl - araman - 12-29-2013 Hello. I have Lan controller. But It doesnt boot. Its only green led blinking . No eth answer ping, arp etc. all tftp update fail. Is any chance to recovery board to normally function ?? Thanks for help. Re: NonBoot LanControl - wilkxt - 12-30-2013 grenn led blink, means that is it in bootloader mode. You try simply put by tftp? What soft was before upgrade? Re: NonBoot LanControl - araman - 01-01-2014 It have a "home" version 3.21. i tryied put in controler "isp" version. But always fail start upload by tftp (connection timeout) . Now controler wont respond anyway. Re: NonBoot LanControl - wilkxt - 01-02-2014 If you have enabled DHCP, use standard IP 192.168.100, if not, use last IP. Re: NonBoot LanControl - araman - 01-02-2014 Thanks. It works with my IP and WinXP. |
