How to set up INPA1 - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V4 (https://forum.tinycontrol.pl/forumdisplay.php?fid=36) +--- Wątek: How to set up INPA1 (/showthread.php?tid=3050) |
How to set up INPA1 - BMA - 12-21-2024 I need to measure voltages from 0V to about 130V, so I am using resistors divider ( R1 =47k, R2=1k ). How should I properly set up INPA1 in LK4? Or into which input should I connect the measured voltage? Thank youi for help RE: How to set up INPA1 - BMA - 01-09-2025 Thank you for your reply. I have solved it. You may be a greater expert (than me - I am just a beginner) on using LK4 - . Can you please help me with setting up Email in LK4? I set up the Email like this https://preview.tinycontrol.pl/lk4/#/email ( with my credentials) but no emails arrive ( even if I just use Test email sending option). A also tried to use with my email server ( used with No encryption option ) but the same. My network works, because the time is updated via NTP server. Do you have any idea what try? Thanks for help RE: How to set up INPA1 - betterwound - 05-28-2025 (01-09-2025, 11:09 AM)BMA napisał(a): Thank you for your reply. I have solved it.Maybe it's your windows. Try reinstalling it. |
