Maximum number of relays - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V3.5 (https://forum.tinycontrol.pl/forumdisplay.php?fid=28) +--- Wątek: Maximum number of relays (/showthread.php?tid=2527) |
Maximum number of relays - maxvatar - 09-06-2022 Hello all, I'd like to ask, if 5relays (1on board + 4relays board) is maximum I can run with one LanKontrol. If there is a possibility to connect one more relay as a Output5, how can I connect it. Thank you in advance. Regards MaX RE: Maximum number of relays - stAch - 09-14-2022 max 10 1 lk board out1+ 1 LK out5 in board 4 external OUT 1-4 releys on IDC10-2 4 external PWM 0-3 releys on IDC10-1 out 5 simple connect 2 wire for out5 and gnd and connect to the relay coil based by power you used for pwm use releys as out or use boards https://www.ledats.pl/en/kontrolazasilania/2762-control-board-on-off-pwm-overlay-tr.html if you use multiplexer CD74HC4067 [DIY] 4 uotputs control 16channel --> based by arduino ==> max 34 releys or 96 bistable ![]()
RE: Maximum number of relays - maxvatar - 09-14-2022 (09-14-2022, 02:36 PM)stAch napisał(a): max 10 Hello stAch, thank you for reply. I wonder if there is product for "4 external PWM 0-3 releys on IDC10-1" such as https://tinycontrol.pl/en/accessories/boards/relays-board-4x/... or I have to put it together myself. Have you seen any prepared solution for IDC10-1 ? Thank you in advance. Best regards MaX RE: Maximum number of relays - stAch - 09-14-2022 (09-14-2022, 02:45 PM)maxvatar napisał(a): Hello stAch, or try this board for all 10 releys output https://www.ledats.pl/en/kontrolazasilania/3282-expansion-board-v3-on-off-pwm-overlay-tr-lk3.html all external board in shop is redy tu use - you need only LK3 board - mount and ready https://www.youtube.com/watch?v=kEnqTzG0U8s -pwm external board in run RE: Maximum number of relays - maxvatar - 09-14-2022 (09-14-2022, 02:55 PM)stAch napisał(a):(09-14-2022, 02:45 PM)maxvatar napisał(a): Hello stAch, Great. Thank you for hint. Have a nice one. |
