Sofar ME3000SP Modbus - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V4 (https://forum.tinycontrol.pl/forumdisplay.php?fid=36) +---- Dział: MODBUS Urzadzenia Custom (https://forum.tinycontrol.pl/forumdisplay.php?fid=34) +---- Wątek: Sofar ME3000SP Modbus (/showthread.php?tid=2511) |
Sofar ME3000SP Modbus - cocmonka - 07-18-2022 Hello, I have a problem in comunication via RS485 I have LanKontroler v3.8 soft 1.49d with RS485 converter I have epever xtra4415n and comunication works perfect. I use template on Modbus page. I try to get data from Sofarsolar ME3000SP and Sofarsolar 3300tl-g3 with no success. On the ME3000SP is icon RS485, when I connect the cable. The setup of the Sofar comunication is: ID:12, data bit 8, parity NONE, end bit 1, baudrate 9600 It blink only TX led on the converter. I try all combination in sofar settings and also custom settings in LK. Thank for help RE: Sofar ME3000SP Modbus - wilkxt - 07-18-2022 Change ID sofar to 1 and tray RE: Sofar ME3000SP Modbus - cocmonka - 07-19-2022 (07-18-2022, 11:30 PM)wilkxt napisał(a): Change ID sofar to 1 and tray Both inverters has ID:01 ME3000SP - no progress 3300TL-G3 - RX and TX flash and it seems, that comunication works. But on modbus page are zero values. I try also custom settings without success. For example, how can I set this register? SOFAR_REG_GRIDV 0x0206 I try 206, 0x4, INT 16 RE: Sofar ME3000SP Modbus - wilkxt - 07-20-2022 (07-19-2022, 08:08 PM)cocmonka napisał(a):0x206 reg is hex value, in LK modbus settings reg adres you use dec value, 0x206hex=518dec(07-18-2022, 11:30 PM)wilkxt napisał(a): Change ID sofar to 1 and tray Try 518,0x4, INT16 RE: Sofar ME3000SP Modbus - cherriesonce - 07-20-2023 (07-20-2022, 07:38 AM)wilkxt napisał(a): 0x206 reg is hex value, in LK modbus settings reg adres you use dec value, 0x206hex=518dec basket randomMany thanks, it's worked. RE: Sofar ME3000SP Modbus - yotob - 09-18-2025 (07-18-2022, 07:38 PM)cocmonka napisał(a): Hello, Its ability to provide endless entertainment and maintain the charm |
