Current measuremen sensors (0-100 a ac volt) - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler - wersje oprogramowania (https://forum.tinycontrol.pl/forumdisplay.php?fid=4) +--- Wątek: Current measuremen sensors (0-100 a ac volt) (/showthread.php?tid=182) |
Current measuremen sensors (0-100 a ac volt) - bulentkusva - 04-08-2013 which sensor to measure AC 0-100 amps use? Bulebt KUSVA Re: Current measuremen sensors (0-100 a ac volt) - wilkxt - 04-09-2013 maby this http://www.allegromicro.com/en/Products/Current-Sensor-ICs/Fifty-To-Two-Hundred-Amp-Integrated-Conductor-Sensor-ICs/ACS759.aspx now we test this http://www.allegromicro.com/en/Products/Current-Sensor-ICs/Zero-To-Fifty-Amp-Integrated-Conductor-Sensor-ICs/ACS709.aspx and this http://www.allegromicro.com/en/Products/Current-Sensor-ICs/Zero-To-Fifty-Amp-Integrated-Conductor-Sensor-ICs/ACS716.aspx About couple days propably we will add new software that works with this two (acs709,acs716) sensors |
