Low voltage event - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler - wersje oprogramowania (https://forum.tinycontrol.pl/forumdisplay.php?fid=4) +---- Dział: Przykłady zastosowań przez użytkowników. (https://forum.tinycontrol.pl/forumdisplay.php?fid=6) +---- Wątek: Low voltage event (/showthread.php?tid=137) |
Low voltage event - lnc - 01-17-2013 Hi I am trying to use the event facility but I am struggling to understand exactly how it works. I would like a relay to turn off a device when the voltage of the board reaches 11.5v but also to turn the relay back on when the supply has reached 12.5v. Is this possible, if so how? The manual I have downloaded does not reflect the latest firmware. Thank you in advance and thank you for a great product! Re: Low voltage event - lnc - 01-25-2013 Can't be done? Re: Low voltage event - wilkxt - 01-28-2013 Draw on the graph how your voltage is change and when relay off/on |
