OpenHab LK_V35 MQTT problem - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V3.5 (https://forum.tinycontrol.pl/forumdisplay.php?fid=28) +--- Wątek: OpenHab LK_V35 MQTT problem (/showthread.php?tid=1006) |
OpenHab LK_V35 MQTT problem - MGyalu - 12-29-2019 Hello guys! There are several V3.5 devices that I would like to use on an intranet. I couldn't find a solution here so I would like to use OpenHab2 MQTT. Reading the data, but unfortunately I can't switch the relay. Item: Switch Tiny_S {mqtt=">[mqtt:xxxxx/a3f/out0:command:*:MAP(tiny.map)],<[mqtt:xxxxx/a3f/out0 tate:MAP(tiny.map)]" }map: ON=1 OFF=0 1=ON 0=OFF RE: OpenHab LK_V35 MQTT problem - wilkxt - 12-30-2019 example switch out0 to 1 via mosquitto_pub by mqtt.ats.pl serwer mosquitto_pub -h mqtt.ats.pl -t xxxxxxxxx/cmd -m "out0 1" -u user -P password you must use "cmd" on end subscription |
