Auth enabled - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V3 (https://forum.tinycontrol.pl/forumdisplay.php?fid=27) +--- Wątek: Auth enabled (/showthread.php?tid=851) |
Re: Auth enabled - octavvian - 11-02-2017 Thanks a lot. Re: Auth enabled - octavvian - 11-08-2017 Hi, could this sensor be connected to LK3 to mesure AC voltage? http://klinikrobot.com/product/electrical-sensor/zmpt101b-ac-voltage-sensor-module.html In what way? Thanks Re: Auth enabled - wilkxt - 11-09-2017 us this https://www.ledats.pl/en/kontrolery/3421-modul-do-lk3-tr12-.html Re: Auth enabled - octavvian - 11-10-2017 I have that one... not what you suggested. Thanks anyway. Re: Auth enabled - wilkxt - 11-10-2017 octavvian post_id=13952 time=1510143868 user_id=6211 napisał(a):Hi, could this sensor be connected to LK3 to mesure AC voltage? This its be ok, but measure value will be not 230AC but couple VDC. You must count this value to true value. What do you want to use it for? Re: Auth enabled - danpin - 11-10-2017 Hello, Where did you download the fw 1.43b version, on the LAN v3 page just find Firmware V1.40b - 02.08.2017? Thank you! Re: Auth enabled - octavvian - 11-11-2017 Hi, I tough it was proper for measure the AC line voltage. The sensor is designed for arduino AC line voltage measurement and is pretty accurate so i come to you maybe there is a way on hooking and calibrating so it's usable in LK3. Thanks! Re: Auth enabled - wilkxt - 11-11-2017 octavvian post_id=13970 time=1510347846 user_id=6211 napisał(a):Hi, I tough it was proper for measure the AC line voltage. The sensor is designed for arduino AC line voltage measurement and is pretty accurate so i come to you maybe there is a way on hooking and calibrating so it's usable in LK3. I will test this and add to lk3 soft Re: Auth enabled - wilkxt - 11-11-2017 danpin post_id=13968 time=1510321813 user_id=6381 napisał(a):Hello, On this forum http://www.tinycontrol.pl/forum/viewtopic.php?f=28&t=6024&start=60#p13238 Re: Auth enabled - octavvian - 11-11-2017 Right.... speaking of it, eta on a the next firmware?
